Blown fuses
Old Jul 9, 2022 | 08:26 PM
dbsteff83's Avatar
dbsteff83
Stage III
Default Blown fuses
I have a 2002 road king. The battery recently died, the battery was accidentally left on. The battery was charged but when I drove it I noticed the speedo, brake light and turn signals didn’t work. I found a blown fuse, replaced the fuse and everything temporarily worked. I took the bike out and after a couple blocks noticed nothing was working again. I checked the fuse and it was blown again. (The accessories 15 amp fuse) Could a bad relay blow the fuse?
Old Jul 10, 2022 | 11:58 AM
nevil's Avatar
nevil
A blown fuse is caused by a short. Start checking every wire and connection one at a time with a dvm.
Old Jul 13, 2022 | 06:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The short is in the accessory circuit.
First thing to check is the wiring harness that runs underneath the rear fender, unplug the connector and see if the fuse still blows.
Old Jul 17, 2022 | 07:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Well, @dbsteff83 , any follow up?
Socalledchad
Electrical/Lighting/Alarm
16
Mar 2, 2022 06:05 PM
HammerHeD
20
Jun 28, 2021 11:19 AM
michaeldubois
Nov 28, 2017 05:22 PM
tennisailor
Feb 2, 2015 10:46 PM
vbboatcop
Aug 14, 2014 05:50 PM
