Tachometer issue
Old Sep 5, 2022 | 11:52 PM
Delva's Avatar
Delva
1st Gear
Default Tachometer issue
Stock at 3k rpm. Does not drop or move up. Everything else works. Any idea?
Old Sep 10, 2022 | 06:21 PM
Max Headflow's Avatar
Max Headflow
No power to the tach? Model / year would be helpful.. If aftermarket, brand. Does it go to 0 on ignition on.. mechanical or electric tach.
Old Sep 10, 2022 | 09:21 PM
Delva's Avatar
Delva
1st Gear
1999 sportster 1200s
yes power
just doesn’t ramp up as I hit the throttle. Stays at 3k rpm
Old Sep 10, 2022 | 09:48 PM
RANGER73's Avatar
RANGER73
Tach's no good
Old Sep 10, 2022 | 10:04 PM
Max Headflow
If it seems to work normal but just stops at 3K it's pribabably the tach is bad. I've seen tach stick at 3k if the battery voltage is too high.. You'll typically get an error code on the speedo and ICM.
Old Sep 10, 2022 | 10:50 PM
Delva's Avatar
Delva
1st Gear
Ok
can’t find it anywhere. They Don’t make them anymore. Been looking all over no one hv that part number. #67043-99
thanks
Old Sep 10, 2022 | 11:19 PM
Max Headflow
Originally Posted by Delva
Ok
thanks
I think the part number is 67042-99.. There are a few on Ebay,,
Old Sep 11, 2022 | 06:38 AM
bustert's Avatar
bustert
the tach can be tested with the speedo tester any dealer should have.
or
you can test it yourself if you have a frequency generator. you connect to the cam sensor connector 14b.
then you take the rpm to be tested and divide by 60 to convert to frequency that needs to be input to sweep the tach to desired rpm
example: 2000rpm/60=33.3hz.
A: 2000/60=33 tolerance +/- 100
B: 4000/60=67 tolerance 120
C: 6000/60=100 tolerance 210
D: 7500/60=125 tolerance 320
Old Sep 11, 2022 | 08:49 AM
Delva's Avatar
Delva
1st Gear
Thank you. I guess I will take to Harley
rtl2468
Welcome Area Only
22
Aug 16, 2021 04:57 PM
rtl2468
General Topics/Tech Tips
Aug 15, 2021 09:45 PM
BikeAriz2
Exhaust System Topics
Apr 18, 2011 08:22 PM
