p2122 help
Old Feb 8, 2023 | 01:52 AM
chepeone's Avatar
chepeone
6th Gear
still not having any luck, I've tried a set of stock handlebars that were still wired in case the apes has any damage inside, still getting a p2122 code after i shut bike off after a test ride, using data I'm getting 5.2 volts at times and sometimes hits 5.3, TPS and ECM have been replaced, losing my shirt and my mind on this one,all the pins and connections seem to be ok
Old Feb 8, 2023 | 03:24 PM
Ed Ramberger's Avatar
Ed Ramberger
Having repaired countless numbers of these, my suggestion would be to go to Post 8, read TT 418A and replace the terminals as it instructs. Just sayin.
I didn’t see anywhere where it says what year it is. That can matter. 2008s were known for the seat hitting the connector at the ecm.
After a certain year they changed the material and some produced before then that will not resolve after terminal replacement get induction modules.
scubaharley
Aug 29, 2008 08:42 AM
tags
Aug 22, 2008 09:39 PM
refrigerationbiker
Aug 11, 2008 01:24 PM
nemick
Aug 7, 2008 10:58 AM
jbhawley
Jun 11, 2008 05:50 AM
