Battery Voltage Testing
So, testing with a volt meter:
1. After a couple of minutes with the ignition turned on... then turned off: 12.3
2. With ignition on: 11.95
2. While cranking over: 8.7
3. While idling and/or throttle @2000 rpm: 13.87-13.90
So, it seems I definitely need a new battery. But while idling voltage should be 14-14.7 correct? My reading was around 13.9... so wondering if I have a problem with my stator or regulator? Or maybe I am seeing an underrepresented voltage reading from any variance that may be associated with my meter?
Your 12.3 is very confusing. Mainly why I am surprised your other test are good ..
I am surprised it cranked.
That idle test should be at 2000 rpm. Over 13.5. Under 15 depending on battery condition and charge.
Your battery is badly sulfated or worn out.
Charge it on a milliamp maintenance charger 24 hours. Kill the surface charge with headlights on and off. Key off, should be 12.6-12.8. Cranking no lower then 8.7.
Aways test fully charged. All test on both lead of battery and wire
Never load test on bike .
I would replace it if it fails what I suggest. You don't want that last start being at home after removing it from a maintenance charger.
All just my opinion and as a suggestion. Just what works for me.
You can only get good accurate charging readings off of a good healthy battery with the bike running. If you do the tests on a weak battery your voltage readings will be low. From your readings I would replace the battery.
