Shovelhead ground
Old Apr 10, 2023 | 02:22 PM
MarkSG's Avatar
MarkSG
Default Shovelhead ground
Hopefully this will be the right section.
I am doing a frame up restoration on a 1976 FLH. I am starting to go back with the electric and notice all grounds are through the frame.
Including all forward of the neck. Looking at the wiring diagram I see no ground path back to the frame for any of the components forward.
Looks like the circuit through the well greased neck bearings would be a bad path.
Looks like ti would be good to run a separate ground back from the triple tree at least back to the dash.
Thoughts??
Old Apr 10, 2023 | 02:37 PM
Uncle Larry's Avatar
Uncle Larry
Pretty sure there was a separate ground cable up there
Old Apr 12, 2023 | 08:13 AM
bustert's Avatar
bustert
that was a common practice, all the forward grounded to a screw on the lower tree. no issue grounding through the bearings, not that much current flow. the light bucket should have a hot rivet to the harness to shell. the shell ground path is the that screw via the fork.
WesternNSW
Jan 6, 2020 10:15 PM
wydopn231
Jun 18, 2008 10:00 PM
CSA
Custom Models
May 25, 2008 04:31 PM
manji99
Jul 16, 2007 04:36 PM
lavish
Jun 28, 2007 06:21 PM
