U0100 Code 2015 Cvo
Old Sep 19, 2023 | 03:47 PM
michaelD79's Avatar
michaelD79
Stage II
Default U0100 Code 2015 Cvo
Hey Everyone thanks in advance for the help. I have been on here for years reading and can usually find my answer but now I cant. I have a 2015 Cvo Road Glide throwing these following codes. U0100 and B2103.
I originally cut off driving down the street on me. We got it to the shop and it would start and run for about 10 seconds then shut off. We checked all battery cables they are tight grounds seem good as well. Then I would try to push the start button then It would not do anything at all. I would then unplug the BCM then plug it back up then the start button would work again. We changed the BCM out then it would run for a couple min sometimes and do it all over again. Any help would be great. I have searched a few people with the same problem but like they never post what the problem was.
Old Sep 19, 2023 | 03:58 PM
kel03's Avatar
kel03
Welcome to the forums from Ontario, Canada, done any work on it lately? Sometimes faulty battery can throw that code.
Old Sep 19, 2023 | 04:02 PM
michaelD79's Avatar
michaelD79
Stage II
no did a test on battery as well came back good
Old Jan 25, 2024 | 09:10 PM
FL-Mike's Avatar
FL-Mike
2nd Gear
Default Mine is now fixed.
My 23 CVO RG stopped as I turned right from a stop sign on new years eve with 550 miles in it. It would not start. Tried removing the main fue, let it sit etc. They trailered it back to the dealer who worked with the HD engineers. I finally got it back yesterday. The fix was to change the wiring harness.
mikelljames
Aug 15, 2023 07:26 PM
Gtop
Milwaukee Eight (M8)
129
Jun 8, 2019 01:09 PM
Litterbox
Jan 13, 2018 11:22 AM
Ticitme
Nov 6, 2012 07:57 AM
altugo
Screamin Eagle CVO Models
Jan 5, 2009 01:30 PM
