Single Fire Coil
Old Oct 3, 2023 | 01:06 PM
natural gasser's Avatar
natural gasser
Default Single Fire Coil
New DTT ignition, old single fire coil, that tested OK with my multi-meter. Got it installed bike fired up ran while I held the throttle open, when I let go to idle it died, would fire back up for a second, then die. After I let it sit for a few minutes, fired back up and stayed running with the throttle partially open, when I rolled off the throttle it died again. Is the coil getting warm and failing? Getting plenty of fuel.
Old Oct 3, 2023 | 01:41 PM
RANGER73's Avatar
RANGER73
No, your not getting fuel
Old Oct 3, 2023 | 04:08 PM
natural gasser
I have the a/c off, can see it, getting plenty of fuel.
Old Oct 4, 2023 | 11:35 AM
natural gasser
Here's what's weird, coil checks out OK, 3.2 ohms on the front and 3.4 ohms on the rear. Where the plug wire connect, 16.62,
no spark at the plugs however.
Old Oct 8, 2023 | 07:04 PM
Max Headflow's Avatar
Max Headflow
Have you set the timing right?
Old Oct 24, 2023 | 07:14 PM
natural gasser
Timing good. Found the wire coming from the handlebars to the coil with a bad crimp. Coil was getting 12 volts intermittently.
No more band aids, bike will get a Moto-Gadget M unit/new harness this winter.
Titus1
General Topics/Tech Tips
May 17, 2023 12:25 PM
firsthd
Dec 12, 2022 07:31 AM
D_gyver
EVO
14
Sep 15, 2014 06:50 PM
racin45
Sep 24, 2013 09:14 AM
brett.
Electrical/Lighting/Alarm
Jan 31, 2013 12:21 PM
