TBW Mini Connector
I have a 2023 Softail Standard. Removed the handlebars which carry all the internal wiring.
Like a dummy, I buggered up the TBW mini connector ( part # 692011620 ( male, with 6 female terminals (part # 69200307) ). The connector is white 3/4" long and about 3/8" wide and high. In other words, pretty small.
I tried to de-pin that connector by pushing thru the top front hole of each terminal with a safety pin but no luck. Then I tried a paper clip which worked and I was able to pull out a wire. Unfortunately, the "clip" which holds the terminal tightly in the connector broke, Same result on the other wires. (Definition of insanity).
Now, when I put the terminals back in the connector, of course, they wont snap into place cause there's no "clip" to hold them in tight.
Is there another way to de-pin these little pains?? Or, are they one-use units and I just buy a new connector ( about $7 ) and snap in the 6 wires. Certainly, won't break the bank.
Appreciate any insight.
Thanks so much for all the info on these mini connectors.
Seems I was doing it correctly but instead of using an " extraction tool ", I used a paper clip. I think the issue with the "retention finger" is that it's so small and pretty delicate. The force needed to release it easily snaps the piece off. I suppose that doing it many times would give one a better idea of just how much force to use.
I'll just buy another connector and reassemble it.
Once again, thanks
Acky
