How much current does my 2019 FLHTP really use?
Old Dec 29, 2023 | 01:40 PM
Goose_NC's Avatar
Goose_NC
Default How much current does my 2019 FLHTP really use?
How much current does my 2019 FLHTP actually use? It is stated "Charging System. Three-phase, 48-amp high output alternator producing 28 amps at idle, solid state regulator".
I tow trailers, and am considering running a fused wire from my battery to the trailer for that purpose. My volt meter shows above 14 VDC with trailer attached and electric vest running at 50% of less. (I rarely run my vest on high for more than 5 minutes.) My trailers all run LED lights and wiring is good (low resistance). The trailer lights are on a powered trailer converted, so not drawing from the motorcycle harness.
I was also wondering if I should just charge a second battery to handle the USB recharge duties. Do the audio guys charge their audio batteries from the motorcycle charging system?
Old Dec 29, 2023 | 01:46 PM
downzero's Avatar
downzero
You would have to measure it to know. Put a voltmeter on your battery and turn on all your accessories and see if the voltage drops below 13.
Old Dec 29, 2023 | 01:47 PM
eighteight's Avatar
eighteight
I`m positive that if you add the draw of each bulb & the vest and the USB it will be far less than 48A
Consider all the crap powered on a cop bike in full service trim
Most have a second battery ( radio) in the "trunk" and both it and the primary battery stay charged.
There`s a fleet of them where I work and they don`t go flat in service
And most are city miles operating at low speed / rpm
JMO
Old Dec 29, 2023 | 02:11 PM
Goose_NC's Avatar
Goose_NC
JMO
What size secondary battery do they use?
Old Dec 29, 2023 | 02:12 PM
downzero's Avatar
downzero
28 amps even is a lot. If you're worried about draw, putting an LED bulb in your headlight alone removes something like 5 amps of load, which is huge, and the new LED light is going to be brighter and pull a fraction of that.
If you never drop below 13 volts, your charging system is generating enough current to sustain the loads and keep the battery charged, so I wouldn't worry about it.
Old Jan 3, 2024 | 06:25 AM
eighteight's Avatar
eighteight
Originally Posted by goose_nc
what size secondary battery do they use?
315cca
17.5ah
Old Jan 3, 2024 | 09:42 AM
downzero's Avatar
downzero
315cca
17.5ah
That adds over 50% capacity, not trivial.
That said, my Dyna has a 20 amp hour battery and the touring bikes have a 30 amp hour, so they already have 50% more capacity. Sure, my touring bike has a radio and heated grips and such, but the engine the battery ultimately has to start is the same.
Will Belden
Aug 6, 2018 08:13 PM
IUOE ROB
2014-2024 Touring Models
Jun 28, 2017 11:01 PM
IUOE ROB
18
Mar 16, 2016 09:56 AM
sgoharley
May 19, 2014 10:30 AM
vulhalla
May 16, 2007 06:26 PM
