trailer wiring
Old May 16, 2007 | 11:05 AM
vulhalla's Avatar
vulhalla
Default trailer wiring
i bought a trailer/toy hauler kinda sortof and it has 2-12 volt lights that are wired into the trailer wiring hookup for the truck so when your parking lights are on, you can turn these on. What I want to do is hook them up to a battery that i want to put in the trailer.
The lights have 1 wire for power and i guess the bulb socket is grounded to the trailer. so what do I have to do to hook this to the battery, put the power to the lights from the battery and run a wire from the negative to the trailer?????
Old May 16, 2007 | 11:11 AM
tbone52's Avatar
tbone52
Default RE: trailer wiring
That sounds correct. Find a screw or drill a hole and use a self tapping screw to hook a ground wire from the battery to the trailer. This will complete the circuit.
Old May 16, 2007 | 12:47 PM
Lpye's Avatar
Lpye
If you have a 7 pin plug on your tow vehicle, there is a constant hot tha you can wire to the battery on your trailer to keep it charged as well.
Old May 16, 2007 | 12:56 PM
Hagar the Horrible's Avatar
Hagar the Horrible
In between the wire going to the battery you can add a switch and a fuse. Put the fuse close to the battery and the switch someplace esay to get at.
Old May 16, 2007 | 01:05 PM
Train Train's Avatar
Train Train
Also take the tailight wire that is now running the lights and hook it to the pos. post of the battery and it'll help charge the battery when the tailights are on.
Old May 16, 2007 | 06:26 PM
vulhalla's Avatar
vulhalla
Great, thanks guys
Will Belden
Aug 6, 2018 08:13 PM
Jasontd91
Jul 11, 2016 01:45 PM
IUOE ROB
18
Mar 16, 2016 09:56 AM
jbhawley
Sep 1, 2008 09:15 PM
chesterbud
Apr 28, 2008 03:09 PM
