BCM error codes
Old Aug 16, 2024 | 11:20 PM
SkylarW's Avatar
SkylarW
Stage IV
Default BCM error codes
I just purchased a 2018 FLHX(Street Glide), 10,000 or so miles. It is throwing 3 different codes and all are pointing towards the BCM or CANbus?? U0001, U0184, U0140… My entire infotainment system will flash and stay on maybe 30 seconds max then go back off and repeat the cycle indefinitely. Sometimes it may stay on for longer however it ultimately shuts off.
Old Aug 17, 2024 | 07:16 AM
GalvTexGuy's Avatar
GalvTexGuy
Is the bike completely stock? If not, give a rundown on what is not stock.
Old Aug 17, 2024 | 07:20 AM
SkylarW's Avatar
SkylarW
Stage IV
As far as the dealer made me aware, the only thing done to it is a key fob delete.
Old Aug 17, 2024 | 07:22 AM
GalvTexGuy's Avatar
GalvTexGuy
So, it has OEM handlebars, lights, etc.?
Also, when did this start happening? Just all of a sudden?
Old Aug 17, 2024 | 07:24 AM
SkylarW's Avatar
SkylarW
Stage IV
That is correct. Everything I’ve read goes to stuff like that and that’s why I’m totally stumped.
and as far as I know it was all of a sudden like I said just purchased it yesterday.
Old Aug 17, 2024 | 07:31 AM
GalvTexGuy's Avatar
GalvTexGuy
If I were you, I’d take it back to where you bought it.
Old Aug 17, 2024 | 08:42 AM
SkylarW's Avatar
SkylarW
Stage IV
Is there anything easy you could recommend to do or look at? The dealership is quite a drive. 2-3 hours if I can keep from making that drive again
Old Aug 17, 2024 | 09:38 AM
GalvTexGuy's Avatar
GalvTexGuy
There are several things that can cause these codes. In your case, the U0001 code most likely caused the other U-codes. Without an electrical diagnostic manual, a wiring diagram, a multimeter and the knowledge to troubleshoot circuits, you’ll be chasing your tail. The dealer will connect the bike to their computer to troubleshoot and determine the cause of the codes.
Old Aug 17, 2024 | 09:43 AM
CoolBreeze3646's Avatar
CoolBreeze3646
1. Take the battery out and get it load tested. Then report back.
2. How old is the battery?
3. Check all fuses.
4. If all checks out good take it back and have the dealer address the codes.
sjones73
Apr 6, 2019 05:18 PM
theindian
Jun 4, 2011 05:45 PM
lkman111
Jul 27, 2008 07:36 PM
earlehd
Apr 6, 2008 07:33 PM
HDF Tech
General Topics/Tech Tips
Jul 21, 2005 10:41 AM
