Speed Sensor
Old Sep 16, 2024 | 05:32 PM
NTrider's Avatar
NTrider
Default Speed Sensor
The bike I am working on has an 07 6-speed transmission. The bike itself is an 06 Night Train. The wiring harness is an 06 NT.
Situation: in order for the receptacle at the end of the speed sensor to match up with the wiring harness I’m using an 06 speed sensor (5-speed box).
Question: Will using a 5-speed sensor on a 6-speed trans work?
Or should I graft the 5-speed receptacle end onto the 07 speed sensor?
Old Sep 17, 2024 | 07:17 PM
TexasScooterTrash's Avatar
TexasScooterTrash
No free answers. Ya gotta do yer own homework. Search ronniespartsfinder.com look at both years and see if the part numbers are the samn.
Old Sep 17, 2024 | 11:00 PM
Max Headflow's Avatar
Max Headflow
For 1, I didn't know whether or not a 07-up six speed softail tranny would fit a 06 - earlier softail. If it worked, cool. Rubber mounts are not interchangeable due to oil tank passages.
I suspect that if the speedo sensors are the same from the tranny surface down then the early sensor will work. If not you'll have to swap connectors. One thing to note is that the speed will likely be off and you'll need some sort of flash program or aftermarket efi programmer to get the speedo reading correct.
Old Sep 18, 2024 | 06:37 AM
NTrider's Avatar
NTrider
I’ve been doing my homework. I have checked Ronnie’s H-D and the sensors are different. Actually the 06 5-speed sensor is shorter where it slides into the the trans. It also has a pigtail where the 07 sensor has a female receptacle without a pigtail.
The 07 six speed is mounted behind an 07 96”. Both fit in an 06 Night Train frame.
The 06 sensor has red, white and black wires. I’m at the point of trying to determine which of the three prongs on the 07 sensor correspond with the 06 wires.
Old Sep 18, 2024 | 08:07 AM
Max Headflow
The big one is, how does the primary line up?
SportyChase
May 5, 2021 03:37 AM
Crashrdking01
Sep 6, 2018 12:18 AM
NightTrainRob
Sep 23, 2015 10:44 PM
Notquitemusashi
Jul 5, 2013 08:11 PM
emperor wurm
Oct 5, 2011 04:09 PM
