Battery??
Old Oct 24, 2024 | 01:33 PM
LoneRiderFLH's Avatar
LoneRiderFLH
Default Battery??
Had an almost no start at a rest area. Check engine light came on. Codes said low volt ECM and high volt ABS. Cleared codes. Did not come back on on cold start next day.
Volts on battery 12.7 cold. Turned ignition on for a few minutes and volts dropped to low 12s. Started bike and volts dropped to 7.9 lowest reading on startup. After startup, volts consistent at around 14.5 even at high revs.
Time for new battery? Think ruled out regulator? Think battery failing load side? Battery is stock from 21 Roadking. Connections checked and seem tight and clean
Old Oct 24, 2024 | 01:53 PM
MURPHCC1's Avatar
MURPHCC1
Have it load tested at any auto store but sounds like it's toast.
Old Oct 24, 2024 | 01:55 PM
Goose_NC's Avatar
Goose_NC
What temperature was the "almost" no start?
First cold spell, or hot spell, can show weakened battery. A battery check can be done. I also consider the age of the battery. If over 5 years, I just replace it if no other issues arise.
To check, I charge my battery outside of the bike. Let it rest for a couple hours. Then check at rest voltage. I will do a load test and monitor voltage. Since you already saw 7.9 volts on startup, I'd bet you have a bad cell.
Old Oct 24, 2024 | 02:28 PM
KK0G's Avatar
KK0G
You just load tested the battery when the voltage dropped to 7.9 volts while cranking and it failed miserably. I'd do an actual load test to confirm but you need a new battery.
Old Oct 24, 2024 | 02:44 PM
LoneRiderFLH
Thanks for replies! Definitely replace battery pronto
Old Oct 25, 2024 | 08:06 AM
cobra23's Avatar
cobra23
Interstate makes a high CCA battery for your bike.
Old Nov 6, 2024 | 07:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Battery is Kaput.
Old Nov 6, 2024 | 08:41 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
You need a new battery. How I check them after making sure connections are clean and tight and an overnight charge.
Keeping it on a maintenance charger all the time will only guarantee the last start will be when you leave home.
My vehicles sit a lot and in two locations. I have one of these in all of them.
I watch key on, cranking and running down the road. Never been stranded.
Roni
Aug 5, 2024 05:13 AM
lonerider1960
Oct 17, 2022 10:50 PM
WOLFE1584
Mar 12, 2013 01:13 PM
Curious.Yogurt
Jun 26, 2009 10:26 PM
B.A.
Jul 25, 2007 02:47 PM
