1992 Electra Glide FLHS
1. Can anyone tell me or have a diagram showing how the trunk lights connect to the bike wiring?
2. On the '92 do the trunk lights serve as both, running & brake lights?
Yes sir, someone did add the trunk and the fairing. The fairing looks to be off of a 2012 or so. My VIN is coming up FLHS Sport so you're right. I almost have it right, except one light gives a bright brake light, the other gives normal running light. Both truck side lights are also normal. I'll try a make a quick video someone has fabricated.
I've made a good video showing what I have but this site won't let me upload it.
This harness is going into the trunk hooked up to a relay.
Same harness going into the trunk hole hooked to relay.
Same harness hooked to relay.
Different plug going to the fender taillight I've temporarily tapped into.
Harness inside the trunk from the harness I've tapped into. Note: No black wire here like the bulbs have.
Both bulbs have red, green, black.
Same color wiring in the left bulb.
[img alt="When I power up at the ignition switch one bulb gives running light illumination. The other bulb gives a brighter brake light illumination. Theres gotta be an easier way to wire this.
Sidenote: Both side lights on the trunk appear to illuminate normal. "]https://cimg3.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/20241125_164429_18c9eb05d32acf4c0c8c34718935578746 b91887.jpg[/img]
When I power up at the ignition switch one bulb gives running light illumination. The other bulb gives a brighter brake light illumination. There's gotta be an easier way to wire this. Sidenote: Both side lights on the trunk appear to illuminate normal.
These are the trunk taillights.
Do both bulbs have double filament and 12V P21/5W stamped on them? It sounds like one bulb is mounted into the fitting in the wrong way and or the wiring at one fitting has to be switched
Yes, both have double filaments. I found not only an incorrect 1176 bulb in one socket. But, it also was in backwards. I put two new 1157 bulbs in and now I have taillights & brake lights when rear pedal is engaged. Now, hopefully all the wiring is correct on the relay someone has in the trunk. I have no idea....
Did you manage to find out where this 2 wired harness comes from?
What wire is at what post at the relay??
This plug looks like plug # 22B in the 1991 FLHS Domestic Models Wiring Diagram (attached). Red seems to be stoplight and Green seems to be rear light and rear fender tip lamp.
Blue and red seem to be collors used in the trunk and fender tip light of the FLTC Ultra
Red is stop
Green is rear light
Black is ground
Red is stop
Green is rear light
Black is ground
See my remark above. It looks to me the relay is not used.
Normally the relay pins are wired as follows:
30 is connection to battery
85 is connected to ground
86 is connected to switched power
87 is normal open (NO)
87a is normal closed (NC) contact
I have no clue why that 5 pin relay is in your trunk. Here's a link to some more info on the use of relays.
