Need some technical advice... bike ran fine yesterday2007 roadking... had 3 broke wires in plastic housing under the tank/ they are fixed now...Not getting power to speedometer, no turnsignals and wont start...Fuel pump kicks on, high beam/low beam works, horn works, and tail light works... All fuses under right side panel look fine ... are their any im missing?I suck with electrical and im needing some advice on what to look for next
Three wire in plastic housing. Check fuses with volt meter with those two pins in top. Be sure both have voltage to ground. Or pull and ohm check fuse.
Dou you have power on INSTR and IGNITION fuses when ignition is on?
Bike ran fine,
had 3 broken wires under the tank
What made you lift the tank?
Did it not start then you started looking and found the broken wires?
Check the last things you touched.
How could the bike run fine, then all of a sudden you have 3 broken wires?
