Add a relay for dual horns
Old May 17, 2022 | 02:51 PM
Hey Man's Avatar
Hey Man
Default Add a relay for dual horns
I'm planning to switch from a single horn to dual horns (not air) on my '93 Heritage Classic. I assume I'll need to add this universal relay but have no idea how to wire it. Any thoughts???
Old May 17, 2022 | 03:17 PM
mike131's Avatar
mike131
You only need one relay, you just need to run a power wire from current horn power to additional horn and ground it
Old May 17, 2022 | 03:37 PM
IBDAGRIZ's Avatar
IBDAGRIZ
I've used a relay on single horns with good results, so for duals it should work nicely.
You'll want a designated 12 volt power source to power the horns into the relay. Ground wire from relay to ground. Power from relay to horns and the original horn wire to the relay trigger connection to engage the relay upon pushing the button.
Try it both ways and see the difference.
Griz
Old May 17, 2022 | 04:45 PM
t150vej's Avatar
t150vej
30 - power from breaker
85 - ground
86 - power from horn button
87 - power (out) to horn
87a - not used (but recommend it be insulated - it'll be hot anytime power is on 30, except when power is on 86) Or, you could use a 4 post relay which does not have post 87a
Old May 18, 2022 | 06:25 AM
Hey Man's Avatar
Hey Man
Thanks for the responses and info. With your help I got everything in and functioning properly. Hopefully I can repay your help and effort somewhere down the line.
bjarnold1
Electrical/Lighting/Alarm
Jan 19, 2018 01:37 PM
charlie31545
Oct 22, 2016 06:48 PM
ghoticov
Jul 22, 2013 08:30 PM
89 FXRS
Jan 14, 2012 11:33 AM
98glider
Ironhead
Aug 3, 2009 09:32 PM
