Codes
Old Sep 18, 2025 | 08:42 AM
Maxwell247's Avatar
Maxwell247
Stage III
Default Codes
Good morning looking for some help in where to look to try and fix the following codes B2121, B2122. Bike is currently trying to start when it’s shut off unless I unplug the wire to solenoid . Any help would be appreciated
Old Sep 18, 2025 | 08:51 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
It is always very helpful to start with what the model and year of bike is.
Some bikes use a BCM that powers the solenoid directly and some use a starter relay.
The codes however are:
B2121 Starter output open
B2122 Starter output shorted high
Old Sep 18, 2025 | 08:58 AM
Maxwell247's Avatar
Maxwell247
Stage III
Bike is a 2018 road king special . Wire to the solenoid is how like is getting feed constant power even when the bike off reading 12.5 volts
Old Sep 18, 2025 | 09:07 AM
Andy from Sandy
Some possibly very bad news is the BCM has gone wrong. The problem is the BCM is always powered even when you have switched off.
Get it properly diagnosed. The dealers should have a breakout box that if it works right should allow for the pin from the BCM to be isolated that would remove power from the wire.
smbwn
Apr 28, 2013 08:06 PM
zbuxton
Jul 31, 2012 01:09 AM
racedvl
Aug 12, 2011 09:25 PM
ruin66
Jul 10, 2010 08:36 PM
vztch13
Mar 22, 2010 07:38 PM
