A More Efficient Voltage Regulator.
Old Sep 22, 2025 | 12:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The OP is looking for technical information for an aircraft application, this forum is not the place for that.
Old Sep 22, 2025 | 01:07 PM
WesRagle's Avatar
WesRagle
6th Gear
Did you look at the picture of the charging system? It's pure Harley. I was hoping I could get some help here. You're just being a jerk.
And BTW, your bike is uuuugly.
Wes
Old Sep 22, 2025 | 01:38 PM
WesRagle's Avatar
WesRagle
6th Gear
Originally Posted by bustert
you have a PMG, not an alternator. did you match the regulator capacity to the load??
if you cannot find an hd one, try searching for wind driven systems, will not be small package since most are panel mount
40 amp unit
most units are mosfet now days away from the transistor and scr units. the advantage of the PWM is that they match the out put to the load, not simple on/off so they run cooler and hold a tight reign on the system.
https://www.ebay.com/itm/23394608473...Bk9SR6iO85euZg
HI Bustert,
No, I haven't looked at that one.
I was able to get in touch with J&P Cycles tech support, and they have pointed me to another one that might fit the bill.
Thanks for The Help,
Wes
Old Sep 22, 2025 | 04:31 PM
WesRagle's Avatar
WesRagle
6th Gear
Thanks Ranger73,
That looks like a winner. From that web page.
A more efficient approach to rectifying regulators.
To control voltage on Harley-Davidson alternators other rectifier regulators dump current to ground. This causes maximum stator current and temperature at all times. Cycle Electric rectifying regulators block current to control voltage. This reduces stator current resulting in lower temperature and less drag on the motor which means more efficient operation. The largest and most noticeable benefit is a smoother charge to the battery. This means less battery maintenance and longer battery life.
Much Appreciated,
Wes
Old Sep 22, 2025 | 04:41 PM
propflux01's Avatar
propflux01
Some older Honda motorcycles have an open shunt system for regulation unlike the Harley/suzuki shunt-to-ground. Might look into one of those. I used to convert Suzuki regulators with these because the Suzukis had weak stators.
Old Sep 22, 2025 | 04:48 PM
Schex's Avatar
Schex
Call cycle Electric
https://www.cycleelectricinc.com/
"use with permanent magnet alternators.
To control voltage on Harley-Davidson alternators other rectifier regulators dump current to ground. This causes maximum stator current and temperature at all times. Cycle Electric rectifying regulators block current to control voltage. This reduces stator current resulting in lower temperature and less drag on the motor which means more efficient operation. The largest and most noticeable benefit is a smoother charge to the battery. This means less battery maintenance and longer battery life."
Old Sep 22, 2025 | 04:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Wes
Good night, DICK.
Old Sep 22, 2025 | 04:57 PM
WesRagle's Avatar
WesRagle
6th Gear
[QUOTE=Schex;22121664]Call cycle Electric
Thanks,
Just did!
Wes
Old Sep 22, 2025 | 06:25 PM
WesRagle's Avatar
WesRagle
6th Gear
Good night, DICK.
Thanks, Good night, Peter.
Wes
Old Sep 22, 2025 | 08:21 PM
Rounders's Avatar
Rounders
Good night, DICK.
It didn't take him long to figure it out
Another vote if you want a Harley one get cycle electric
