Battery cca size 2013 fxdf
Old Nov 13, 2025 | 06:29 PM
MyFatBob's Avatar
MyFatBob
Default Battery cca size 2013 fxdf
Battery on bike currently is 310 cca, Seems like it could use a bit more, Battery is over 3yrs old not sure of age.I'm going too replace in spring 2026. Any suggesstions on a replacement?
Old Nov 13, 2025 | 07:37 PM
GalvTexGuy's Avatar
GalvTexGuy
OEM Battery
Old Nov 13, 2025 | 11:27 PM
Bass-M's Avatar
Bass-M
Stick with 310 CCA if it worked for you. For a bit more punch, you can safely upgrade to a 340 CCA battery like the HD BTX30CH. The Yuasa YTX30CH is another solid choice. Just make sure the physical size and terminal placement are the same.
Racepres
Electrical/Lighting/Alarm
11
Nov 4, 2024 01:02 PM
pookguy88
Sportster S
Aug 13, 2024 11:52 PM
Riceburnerfb1
Shovelhead
Feb 9, 2023 02:13 PM
Slim Reaper
Apr 29, 2015 11:08 PM
chunky
Apr 7, 2011 06:50 PM
