Red dot on speedo turning on
Old Feb 27, 2026 | 11:54 PM
RustyShackleford's Avatar
RustyShackleford
4th Gear
Default Red dot on speedo turning on
I’ve got a 2019 iron xl1200ns.
ive also got front and read halo LEDs bulbs. Fronts are drls.
When I ride for extended periods of time with my high beams on, the red dot on my display powers on.
I don’t get hyper flash when my turn signals are on.
anyone have an explanation?
Old Feb 28, 2026 | 05:44 AM
GalvTexGuy's Avatar
GalvTexGuy
Check for codes.
Old Feb 28, 2026 | 05:51 AM
touchdown's Avatar
touchdown
Check your light bulbs
Old Feb 28, 2026 | 07:05 PM
Bass-M's Avatar
Bass-M
Its the security light reacting to a slight voltage drop when you run the high beams for a long time. LEDs draw different power than stock, and the system senses that fluctuation. Check your battery terminals are tight and you should be fine.
Old Mar 12, 2026 | 08:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Another Google answer from Bass-M.
Ignore any answers from Bass-M and you should be fine...
Old Mar 13, 2026 | 09:18 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I know that when my RED indicator on the speedo light up on my 2013 FXDBP, the BCM is letting you know that a current DTC exists. You will need to check for codes..
cdremy
General Topics/Tech Tips
Jul 12, 2023 09:20 AM
LenBoyLo
Electrical/Lighting/Alarm
Mar 23, 2019 09:29 PM
kyote
May 20, 2009 10:56 PM
XfasteddieX
Nov 3, 2007 10:46 AM
bikerRN
Jun 16, 2007 03:47 PM
