Routing Battery Charging Harness
Old Aug 16, 2008 | 07:27 PM
hdzenride's Avatar
hdzenride
Default Routing Battery Charging Harness
Anybody have success on routing the HD battery charging harness for easy access on an 07 wide glide or similar as the terminals are starboard facing out? It doesn't appear flipping the battery around (so terms face inward) is an option....I could be wrong though.
I've searched the forum and don't see the routing issue addressed. Any direction would be appreciated.
Thanks.
Old Aug 17, 2008 | 11:48 PM
acchd's Avatar
acchd
I've got a battery tender jr on my Fatboy. Pretty simple install across positive(+) and negative(-) battery terminals. Just make sure there is no interference with those terminals when you remount seat and you'll be ok. I routed my connector on right side just past oil tank.
Old Aug 19, 2008 | 06:27 PM
hdzenride's Avatar
hdzenride
Thanks for the response ACCHD. Yeah, it's a simple connection that I was able to do, but the routing of the pigtail is problematic in there is no room to route it out the battery case once the cover is installed. One solution I thought of is to drill out the side of the battery housing so I can go out the left side of the bike with the pigtail. I'm not sure if the Fat Boy is configured the same as the Wide Glide.
deadman77
Aug 11, 2013 07:48 PM
CGP93
Mar 22, 2013 06:00 PM
bbqbrisket
Feb 5, 2010 05:24 PM
Shark46
Feb 28, 2009 04:31 AM
toadmanor
17
Dec 8, 2005 02:00 AM
