Light Pods.
Old Mar 31, 2009 | 07:58 PM
Poorguy's Avatar
Poorguy
Default Light Pods.
On my 09 Fat Boy which I'm currently still waiting on (going on 10 weeks), I had/will have them install a set of light pods.
On my way home from wings tonight we stopped at a local HD shop and there was a gorgeous bike sitting out front with similiar lights on it. With the chrome and the sunlight fading, it looked fantastic. I struck up a conversation with the gentleman and he proceeded to tell me he had 120 lights on it and it took them 7 hours to install. I did not see where he had 120 lights on it unless he counted each little LED in each set. As in the ones above would have 10 per set of 6 or 60 bulbs.
Does anyone have pictures of theirs or input towards me adding more lights.
Also, this guy said NOT to buy them from HD but recommended another brand and for the life of me I forgot what he did say.
One more thing, I'm a telephone tech and wired my entire house electrically when I built it as well as several stereo systems in cars, is this something I could do myself.
How much is too much?
EDIT: UPDATE:
I'd like to thank everyone for their recommendation. I had Harley install the first set and I'll be adding more at a later date. I've found a local guy who sells what I want and will be assisting me adding them. SO far she's gorgeous. Enjoy
Old Mar 31, 2009 | 09:47 PM
Squiggs's Avatar
Squiggs
I spent a couple of hours today wiring in some more lights on my bike. The guy you talked with was counting each bulb. I used lights and accessories from CustomDynamics.Com. They have more selections than you can shake a stick at. They take it seriously.
I've seen different colors on countless bikes, but for my money I go with the white lights. They simply light up what you want to accent or show off, instead of drowning it in some fusion of one color.
A couple of tips: Tinker around with the placements of the lights first. Get a feel of where they will fit and where they will work the best. Keep them hidden. Also, it helps to do this in a low-light setting so you can see the effect. Use a 9-volt alkaline battery and hold the wires to the two terminals, and it will power the light so you can get a good idea. Also, the website has several different offerings for connection/terminals to keep from having to solder things.
Hope this helps, and good luck!
Old Apr 1, 2009 | 10:40 AM
frankiefire702's Avatar
frankiefire702
I agree to stay away from the hd brand. Not nearly as bright as some aftermarket and the hd brand are more $$$ too. I went with swint brand leds. Extremely bright and not too expensive. I'm currently switching from the blue lights to white to change it up a bit. The swint are also plug and play so no soldering. If you decided to go swint brand I'm selling my blue pods if you wanted to save a few $$$.
http://swintledlights.com/
Old Apr 1, 2009 | 02:38 PM
JRK5892's Avatar
JRK5892
here man i have wrote a ton on this on this tread.. check it out!
https://www.hdforums.com/forum/dyna-...hting-kit.html
Old Apr 1, 2009 | 07:37 PM
Poorguy's Avatar
Poorguy
Cool Thanks,
Great information and I really appreciate it.
I can tell this is going to be a lot of fun!
Joe, thanks for that link.
Old Apr 2, 2009 | 07:41 PM
garryb's Avatar
garryb
go to www.boogey.com that is the web address for boogeylights. watch the install videos the go to www.superbrightleds.com i got this from them about 2 years ago. 4 /FLB-B18 light bars that you can cut, 1/ LB1-P power lead, and a LB1-I interconnecter lead for each light bar i was going to us after cuting them. works great.i got a on off switch for a guy that installs light kits and the 3m tape at napa
Old Apr 2, 2009 | 08:06 PM
Poorguy's Avatar
Poorguy
Thanks GarryB.
top0211
2014-2024 Touring Models
Oct 30, 2021 07:24 AM
ChrisHo
Electrical/Lighting/Alarm
Oct 7, 2016 06:21 PM
bigblock59
Aug 17, 2016 10:36 PM
TODDNVAL
Dec 22, 2013 03:56 PM
twohats
Apr 24, 2007 03:00 PM
