question about battery and starter
Old Nov 5, 2009 | 12:30 PM
chunky's Avatar
chunky
Default question about battery and starter
Took the Fatboy out for a ride just to the store. Came out and she cranked right up, but cut it off to do something. When I tryed to start the second time, nothing. dont know if its the starter or battery. Got it home and tryed to jump it off, nothing. So im thinking it may be starter or Wire lose. Worked on cars alot but never a Harley but I want to learn. Should I take the battey out and see if its ok and then go from there. Its a 1999 Fatboy with 17000 miles. Oh by the way when I ture the ignition on all the lights come on as bright as normal. thanks....................chunky
Old Nov 8, 2009 | 06:18 AM
chunky's Avatar
chunky
Just wanted to add, are there any wires that connect to the starter button on the handle bars. Inside the handle bar assembly
Old Nov 8, 2009 | 08:11 AM
sqdealgeorge's Avatar
sqdealgeorge
There is a green wire that goes to the starter from the relay Pull that wire off the starter and clean it off Try it
Old Nov 8, 2009 | 08:18 AM
2003Springer's Avatar
2003Springer
did you forget to turn on the kill sw?
Old Nov 10, 2009 | 06:08 AM
chunky's Avatar
chunky
One more question, how hard is it to push a Fatboy off to start it. Can it be done. I tryed but it sure does have a lot of compression. thanks
Old Nov 10, 2009 | 02:25 PM
hdtech.ironthunder's Avatar
hdtech.ironthunder
4th Gear
On you starter there's a trigger wire that comes from you starter relay. Check that wire. They will sometimes vibrate loose. It just pushes onto a tab on you starter housing.
Old Nov 17, 2009 | 08:58 AM
chunky's Avatar
chunky
Ok put the voltage meter on the battery and get 12.5 on the voltage meter which lets me know the battery is ok. What would be the next step to look for because it is acting like a wire is loss but finding the right wire is a very daunting task. Anyone have any ideas. thanks.............chunky
matt_m_72
Apr 8, 2019 08:47 PM
PBL
Engine Mechanical Topics
Jun 19, 2018 10:02 PM
NB Biker
Aug 23, 2014 06:54 AM
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
paul d
EVO
18
Aug 30, 2010 09:15 AM
