turn signals
Old Jun 19, 2010 | 09:52 PM
OMM's Avatar
OMM
Stage I
Default turn signals
2002 XLC 1200 sport that both front and rear left turn signal work fine. The right front and rear eliminates solid (bright ) and the turn indicator (Arrow) stays on. I have checked the bulbs and all of the filaments look fine. Do I have an issue with the turn signal module and if so were is it located?
Old Jun 20, 2010 | 07:17 AM
stevelonewolf's Avatar
stevelonewolf
I wouldn't say it's the module yet. Those are not cheap. You may have a grounding problem on that side. Or even the turn signal switch.
Old Jun 20, 2010 | 07:43 PM
asm481's Avatar
asm481
I was just gonna post a similar problem with my 02 RK. First thing that happened was my right turn signal would not cancel. The indicater lamp got dim but it continued to flash wether the left turn was used or not. Left signal worked as normal. I was several hundred miles from home so this is what I did. First I unpluged my run/turn/brake module and switched my front bulbs around. (right to left and left to right.) Now the left turn signal was screwing up. Thought great just a bulb. I changed bulbs (both front) and now it seems to work EXCEPT...Both sides blink normal for 4-6 blinks then blink real fast like years ago if you plugged a trailer into a car that didn't have a heavy duty flasher.
Sorry for long story but somewhere there has to be a fix for both of us.
Old Jun 21, 2010 | 07:50 AM
asm481's Avatar
asm481
Monday morning bump
Pragmatic
Feb 8, 2015 07:50 PM
Madness04
EVO
42
Sep 8, 2013 07:51 PM
stevel
Jul 25, 2012 04:51 PM
unclerogi
Jun 16, 2012 09:13 PM
obx streetglide
Mar 14, 2011 03:11 PM
