Battery starter problem
Old Jan 22, 2011 | 12:36 PM
hey stoopid's Avatar
hey stoopid
6th Gear
Default Battery starter problem
wierd thing - for me anyways
trying to start bike ('91 FXR ) solenoid clicks , starter turns engine over almost. then just clicking solenoid. battery is charged (checked ) and good (checked) so a flat battery is ruled out
funny thing is it was ok the other day but yesterday no go
have put on a new battery with the same results
seems to me the starter is needing more power than the batterys' got
the terminals get quite warm
i seem to remember reading a thread along these lines before
any input greatly appreciated
Old Jan 22, 2011 | 07:20 PM
TwiZted Biker's Avatar
TwiZted Biker
Check your cable connections , sounds like a loose ground or something is corroded a bit if the battery is holding a decent charge and the cables heat up like that .
Old Jan 23, 2011 | 04:17 AM
hey stoopid
6th Gear
did have a look but initial inspection didnt throw up anything obvious.
just wondering if it could be damp as we've had some real rain here over the last few days.
struck me as funny that it was yes!!! then no!!! and no maybe? with it
the joys of harley ownership.
cheers
Old Jan 23, 2011 | 10:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
cheers
Quit whining...It`s a 20 year old machine for cryin out loud...
Remove, clean and re install all electrical connections between the battery and solenoid, and also the connections between the starter relay and solenoid.
You might want to take a look inside the solenoid to be sure the contacts are ok.
Old Jan 23, 2011 | 03:49 PM
hey stoopid
6th Gear
maybe you've heard of irony?
Old Feb 13, 2011 | 07:08 AM
hey stoopid
6th Gear
filed the spring down in the solenoid
worked a treat
wasnt going in enough as the contacts were worn
got a few more months out of it before a rebuild
old bikes never die
hurrah!!!!
Old Feb 13, 2011 | 09:24 AM
UncleChey's Avatar
UncleChey
woo to old bikes, I got a 30 year old one that im trying to finish restoring, the hard work is done, and i didnt have do it, but i have to do the electrical work,
at least im having fun with it though, learning alot
Old Feb 13, 2011 | 12:41 PM
ClutsDeluxe's Avatar
ClutsDeluxe
Default 05 Deluxe won't start
sorry wrong thread
Old Feb 15, 2011 | 05:20 PM
MatSubZero's Avatar
MatSubZero
I've had the same problem with my '86 883/1200 Sporty. I think it might be the cheap-*** EverStart WalMart batteries I've been running...? I am in the process of installing a high torque (1.4kw) starter and fatter battery cables and getting a battery with 310 cold cranking amps (as recommended by Debrix, where I got the starter). This is my last resort before installing compression release valves!! I'll let you know if this fixed mine when I get the installations done next pay day.
DEric24
Electrical/Lighting/Alarm
Jul 3, 2015 08:53 AM
DynaDAWG
Apr 13, 2015 08:05 PM
stephtell
EVO
13
Mar 2, 2015 09:20 AM
bugzapper
Aug 30, 2014 12:01 PM
teeboz
Sep 4, 2013 01:50 AM
