starting problems
Old Feb 26, 2011 | 07:03 PM
bulldoglr's Avatar
bulldoglr
Stage II
Default starting problems
i have a 81 shovelhead and it has kick and elect. start, sence i had it ive never been able to kick start it and the only way it would start is by using the choke. i could ride 30 miles and stop for a smoke and i still have to choke it and when i first start the bike i almost drain the battery. i installe new intake bands and gaskets and cleaned out the carb and installed new points kit.
any help thanks
bulldoglr
Old Feb 27, 2011 | 09:16 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Did you reset/check your timing after the points install. Dwell changes timing but timing doesn't change dwell.
Another thing you should check is that the advance mechanism is working and not froze/locked up.
Old Mar 1, 2011 | 09:15 AM
bulldoglr's Avatar
bulldoglr
Stage II
hey thanks ill check that
J.Brady
Carburetor Related
Feb 5, 2019 08:37 PM
nolabel
Apr 17, 2016 10:29 PM
Oldsarge29
May 7, 2013 04:10 PM
Chuckharley
Shovelhead
Jan 12, 2010 03:04 PM
albionphill
Panhead
Oct 19, 2007 02:26 PM
