Toggle Aux Lights On/Off without a switch
Old Jan 27, 2012 | 12:52 PM
OldNavy66's Avatar
OldNavy66
Question Toggle Aux Lights On/Off without a switch
I have ordered the lightbar kit for my 2010 Fatboy Lo and ran across the Custom World Smart Switch (part No. 05-777) that claims you can toggle your passing lamps on and off using the Hi/Lo headlight switch; no other switches are necessary. I have done a search in this and the Softtail forum with no results. Has anyone out there tried this device? I have only seen reviews from metric bike owners.
Thanks folks.
A Smart Switch, part number 05-777
(Custom World) is an alternative and takes the place of a standard relay and switch.
This is a sealed latching relay unit that can be installed anywhere, or in your headlight shell.
This is a very easy way to use a sealed relay and have switching all in one.
Standard wiring and control for the Smart Switch .
Custom World Smart Switch Electrical Connections
Motorcycle Smart Switch
Hi beam headlight wire- orange wire
Light Bar Spotlamp- white wire
12 Volts (Accessory power when key is turned on)- yellow wire
Ground- black wire
How the Smart Switch works:
click to hi beam on OEM switch = Hi Beam - On Spotlamp - ON
click to lo beam on OEM switch = Lo Beam - On Spotlamp - ON
click to hi beam on OEM switch = Hi Beam - On Spotlamp - Off
click to lo beam on OEM switch = Lo Beam - On Spotlamp - Off
Then the cycle repeats itself.
Every time you switch to Hi-Beam your aux. lights change. If they are on they go off and if they are off they go on.
http://store.valueaccessories.net/sm...arylights.aspx
Garrman
Electrical/Lighting/Alarm
Jan 8, 2019 03:44 PM
bnfzep
Jul 13, 2012 07:27 PM
trslim
Jul 29, 2009 04:55 AM
Demonsmasher
Jun 15, 2008 09:54 PM
LazyBob
Mar 24, 2006 07:21 AM
