wantoride
Old Apr 2, 2012 | 10:48 AM
wanttoride's Avatar
wanttoride
Stage I
Default wantoride
help! o2 fatboy fuel inj problem run's but light's dim and flicker speedo wont work run's for about five min's then die and it's as if you turned ign off wait apporx 02 min's you can hear a relay click and will start and go again for about the same amount of time help!!!!!!
Old Apr 3, 2012 | 11:04 AM
UltraNutZ's Avatar
UltraNutZ
check the system relay under the seat. also check your battery cables for good solid ground connections.
ResidentPirate
Apr 11, 2013 11:22 AM
eazyrider
Jan 20, 2010 08:25 PM
tfaucett
Jul 22, 2008 08:10 PM
ridingfreddddd
May 27, 2008 07:12 AM
Barrington61
May 20, 2008 04:30 PM
