LED lights
Thanks
It is plug-n-play & works just fine BUT it is a 3157, and not a 3457. Which means the running light brightness matches the OEM incandescent bulb brightness exactly, but the brake light brightness is much less than the OEM incandescent bulb brightness. That's actually normal for a 3157. It normally has about 100 lumens less brightness on brake than a 3457.
It works for me & I'm satisfied with it, but you must be aware of the difference.
I've looked, but been unable to find an LED 3457.
The next step up is something like a $100 Radiantz 136 LED fixture, but that's a bit more $ than I'm willing to part with.
