Led problem
Old Mar 5, 2013 | 06:48 PM
Sfcg77's Avatar
Sfcg77
Default Led problem
So I picked up a few sets of aftermarket led bulbs that plug right in. I thought it was a great idea. Led look without having to replace the whole taillight. So I put the led bulbs in and they work fine but the blinker indicator is blinking really fast indicating I have a blown bulb. I'm sure it has something to do with the voltage level being a lot different than the oem turn signal bulbs. Anyone know how to fix it? I really like the look of the led turn signals and would like to keep it but the fast blinker indicator is driving me crazy. Any suggestions? Thanks everyone!!
Old Mar 5, 2013 | 07:37 PM
RANGER73's Avatar
RANGER73
I see you didn't do a search.
anyway to answer your question, you need load equalizers, 1 for each led turn signal.
Old Mar 5, 2013 | 07:49 PM
Sfcg77's Avatar
Sfcg77
Actually I did do a search just under the electrical and lighting section with no luck so I posted this. I found the search feature on the main page and found a thread on it. Thanks
Old Mar 5, 2013 | 07:51 PM
RANGER73's Avatar
RANGER73
Ya, takes a while to figure where to look. But the search is your friend.
Old Mar 5, 2013 | 07:55 PM
Iceman24's Avatar
Iceman24
Sfcg77; can you go back to the LED bulb supplier & ask if they have the solution (load equal) for their product. I know it probably shouldn't matter, but sometimes getting parts from same manufacturer/vendor works best - good luck!
Old Mar 6, 2013 | 01:40 AM
Nextbite821's Avatar
Nextbite821
Get a signal conditioner. All of what I have heard, load equalizes get really hot, and for instance, if you put on your Em. Flashers, and walked away from the bike for a couple hours, you may not have one when you return. I was told, they get that HOT! Take to a led supplier with more knowledge than me, and hopefully they can put you on a safe track to solve your problem....
omalley72
Mar 9, 2024 04:49 PM
SteddyTeddy
EVO
Jan 23, 2019 09:17 AM
nyokie
EVO
Apr 9, 2016 03:47 AM
JakeUSAF
2014-2024 Touring Models
31
Oct 27, 2014 02:18 PM
