Sportster electronics problem
Old Apr 4, 2013 | 03:02 PM
nkramer6's Avatar
nkramer6
Stage III
Exclamation Sportster electronics problem
I have a '99 Sportster with a wideglide front end. I didnt have a garage to put the bike in over the winter, so I just threw a cover over it and left it outside. One night I came home and it had been tipped over for probably 12 hrs tops. Another time, my roommate decided to take back his cover right before 5" of snow, i then proceeded to kick his ***, and got a new cover. Other than that the bike hasnt seen any kind of weather or problems.
I went to fire it up for the new season.... turned the key and nothing works. no lights, no odometer, starter wont even click. I put on a new battery, checked fuses, brushed off all the terminals and connections. Any idea of what could be the problem? Im pretty good with wiring and cant see any damage to the harnesses or connections.
Any help would be greatly appreciated, its about to be really nice out and I am dying to ride. Shoot me some ideas please!
Old Apr 17, 2013 | 09:43 AM
UltraNutZ's Avatar
UltraNutZ
check the main circuit breaker located behind the left side cover. should have 12v on both posts.
also remove and inspect your battery cables thoroughly.
if neither of these is your issue then odds are you have a bad ignition switch which can be verified with a volt meter
HImilou
Custom Models
Oct 17, 2015 06:11 PM
nkramer6
Apr 4, 2013 10:45 PM
nkramer6
Apr 4, 2013 03:01 PM
manuel_hero
Aug 3, 2012 09:33 AM
cjm80
Oct 10, 2008 05:38 PM
