Front turn signal issue
Old May 25, 2013 | 06:38 PM
08Frightster's Avatar
08Frightster
Default Front turn signal issue
I have an 08 Nightster. The front right turn signal bulb is a dual filament and the running filament works but when I hit the button the running filament starts to blink not the signal filament. The rear filaments work as they should just not the front, and its only the rightside. Checked resistance and doesn't seem to have a short between the socket and the connector (front to connector & rear to connector).
Old May 27, 2013 | 12:29 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Did you try swapping the bulbs to see if the issue remains?
Old May 28, 2013 | 09:02 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Have you checked if the bulb has been put in as it should?
Dual filament bulbs have two little staggered pins and double poles.
riiano
Jan 10, 2013 08:26 PM
gilyoyo
Nov 1, 2010 03:07 AM
holt2010
Aug 8, 2010 09:20 PM
tail11
Aug 9, 2007 11:21 PM
guild
General Topics/Tech Tips
May 22, 2007 03:07 PM
