2006 heritage electrical question
Old Aug 17, 2013 | 04:59 PM
6D6's Avatar
6D6
3rd Gear
Default 2006 heritage electrical question
Bike won't start and starter just clicks. I took battery cables off to clean the connections I noticed that when I was connecting the ground cable back up there was a small amount of arching going on. The ignition was off. Seems like something is drawing current when bike is off or is this a normal event? The battery is only 2 years old.
Old Aug 19, 2013 | 12:50 PM
grbrown's Avatar
grbrown
Wink
It sounds as if your battery is down on power, probably quite a lot. I suggest you remove it from the bike and charge it overnight. It should hold well over 12 volts once charged.
The problem may be down to a duff battery, or your battery is not being charged properly while riding. There may be another problem, of course, but try the basics first and let us know what you find.
There are helpful stickys at the top of this section, on checking your charging system. You will need a multimeter.
katn0
Electrical/Lighting/Alarm
Jun 28, 2015 08:36 AM
Vic Bronco
Sep 21, 2013 12:07 AM
skullandcircle
Jul 30, 2007 09:55 AM
riles10
24
Mar 30, 2007 06:14 PM
hdpig
Dec 27, 2006 12:21 AM
