Slow start issue 2012 softail
Old Feb 16, 2014 | 04:27 PM
notimeleft's Avatar
notimeleft
Default Slow start issue 2012 softail
My softail seems to turn over very slowly after only a day or two sitting in the garage. I had the HD dealer check the battery and charging system. They said everything checked out OK. They even check all the connections. After I take the bike for a ride, if I stop during the trip, when I try to start it., the engine turns over very fast and fires right up. So I don't think it's a starter issue. Could it be the stock HD battery is just borderline for this size engine? Would I be better off going to a higher CA battery? Any experience with this issue, please share.
Old Feb 16, 2014 | 11:11 PM
slapshot12's Avatar
slapshot12
My bet is battery. Mine did the same thing. if they just checked the battery voltage and not a full load test, it will likely test ok. Mine would crank slow for a couple seconds, delay for a second, then fire up....even on a battery tender. The battery voltage tested fine, but didn't do so hot on the load test. A new stock battery solved the problem, she fires right up now.
Old Feb 17, 2014 | 05:44 PM
notimeleft's Avatar
notimeleft
They said they load tested it. They even checked the regulator. Oh well. thanks for the reply.
Old Feb 17, 2014 | 05:47 PM
notimeleft's Avatar
notimeleft
slapshot, you don't remember what your load test numbers were, do you? they showed my battery at 290 CCA. I assume that's the load test.
Cal516
Jul 29, 2019 08:38 PM
izzyfutch
Ironhead
Jun 5, 2019 12:27 PM
YPD485
Electrical/Lighting/Alarm
Oct 15, 2016 06:06 PM
tidbit1
Mar 9, 2015 05:41 PM
Borracho
Nov 17, 2012 05:11 PM
