HELP. Turn signal issue!!!
Old Apr 30, 2014 | 07:55 PM
delonick347's Avatar
delonick347
Stage IV
Default HELP. Turn signal issue!!!
2007 Nightster 1200
Just got done doing tank lift/bar install. Signals worked normally upon mock up. After everything was bolted up for good, right side signals don't blink. Running lights work. Four way flashers work in click side, not on trottle. I know the bulbs are good on throttle side.
Can anyone help??
Old May 1, 2014 | 08:07 AM
Trailblocker's Avatar
Trailblocker
You probably pinched a wire on the throttle side coming out of the switch?
Old May 3, 2014 | 01:39 AM
delonick347
Stage IV
Default Update
After troubleshooting here is what I discovered (pasted from another thread):
Hi guys, please help. My throttle side turn signal switch will ONLY work when the front brake lever is pulled!
2007 Nightster 1200
Installed new bars with internal wiring. Pulled switch housing cleaned out and inspected wires. Can't see any bare wires.
Please help!!!!
splattttttt
Electrical/Lighting/Alarm
Jun 29, 2019 01:41 PM
DAVIDRODE
11
Apr 29, 2017 07:33 AM
delonick347
General Topics/Tech Tips
May 4, 2014 09:16 AM
joneill
Aug 24, 2013 04:54 AM
nytstermark
Sep 2, 2010 05:36 PM
