HELP! 2013 Street Bob Fender/wiring on 2010 Super Glide lighting issue!
Me and my friend recently swapped rear fenders along with wiring. He has a '10 super glide and i have a '13 street bob and everything bolted up fine, the harness went together fine. But when we tried out the lighting thats when the problem showed up. On his SG with my wiring/fender everything works fine except that No Brake Lights turn on when the brakes are pressed!!! I really want to do this swap but i just dont know what to do about this brake light issue. Any help would be appreciated, thanks..
Just to clarify, the electrical parts stayed with the original bike correct?
Check the accessory fuse.
Check for voltage when brake is applied at pin no. 6 on the connector at the rear (the wire color on the main harness side of the connector is blue/red, on the tail light harness side the wire is red/yellow).
We got everything lighting up now as it should. He bought the harness that comes in Harleys Dyna bobbed fender kit (59860-10). I belive the harness part number is 68398-10 it cost $94 shipped to his door from Surdyke H-D and it worked like a charm
