Sportster Died
Old Jul 21, 2014 | 03:41 PM
Timex's Avatar
Timex
Default Sportster Died
1988, 883: Wifey took it out for a ride, started to cut out until after about 5 more miles it quit. When the key is turned on, I get an intermittent clicking sound coming from the ignition module. It clicks for a split second and the lights dim briefly during the "click".
A click every few seconds until I turn off the key.
Replaced 30 amp main breaker, new starter relay and new battery terminal ends. Still no go. Ignition Module is around $260.00, so I dont want to just try one to see if that fixes it. Any other ideas???
Old Jul 22, 2014 | 07:17 AM
nhrider1's Avatar
nhrider1
Sounds like a bad battery. Look at the battery voltage, and check the charging system.
A bad charging system (voltage regulator and stator) will kill a battery in short order.
There are stickies in this section to help troubleshoot the charging system.
JRankin163
Electrical/Lighting/Alarm
11
Dec 3, 2019 05:30 PM
bjc
May 22, 2017 07:36 PM
wright960
May 18, 2014 02:42 PM
Rick Thompson, Tejano
Apr 17, 2013 06:15 AM
blackbobber2
Jul 9, 2012 11:27 PM
