Voltmeter/Charging Question
Old Jul 21, 2014 | 04:06 PM
roussfam's Avatar
roussfam
Default Voltmeter/Charging Question
Hi guys...For the people with Touring Bikes. I was wondering what your voltmeters were showing at idle and when driving.
Jim
Please?
Old Jul 21, 2014 | 07:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model, Year?
Charge the battery on a trickle charger until it is fully charged, then take it to a shop and have it load tested (auto parts store will do this usually for free).
Clean all the electrical connections.
Old Jul 21, 2014 | 08:32 PM
roussfam's Avatar
roussfam
Model, Year?
I was curious what your voltmeter was showing at idle and when driving
Old Jul 22, 2014 | 07:24 AM
nhrider1's Avatar
nhrider1
Originally Posted by roussfam
Hi guys...I was wondering what your voltmeters were showing at idle and when driving. Mine never goes above 14 volts and drops to about 13.5 at idle if I have my driving lights and stereo system on (amp). Just put a meter directly on the battery...12.9 volts at rest.
The reason I am asking is because my bike starts fine when cold, but is hard to turn over when hot, sometimes it cranks so slow it won't start and I need a boost. I am wondering if my charging system is not keeping up when riding.
Jim
I don't think your charging system is keeping up. Although 12.8 or above at rest indicates a fully charged battery.
If your volt meter is accurate, 13.5V at idle is on the low side. Mine never gets below 14.0. I suspect you have a weak regulator.
Old Jul 22, 2014 | 07:33 AM
grbrown's Avatar
grbrown
There are two Stickies at the top of this Tech Electrical section that give advice on checking your charging system, including Dan's suggestion. Use the scientific approach to establish if there is a problem and what it is!
Old Jul 22, 2014 | 10:43 AM
roussfam's Avatar
roussfam
What does your voltmeter read at highway speed?
Old Jul 22, 2014 | 10:46 AM
roussfam's Avatar
roussfam
Did that, everything checks out. Sounds like you either have no charging, very high charging, or fluctuating charging when your VR goes. Just wondering if it's possible to just have it not keep up.....hence the request for the voltmeter readings on other bikes....
Old Jul 23, 2014 | 05:47 AM
nhrider1's Avatar
nhrider1
Mine reads 14.0-at idle and 14.2-14.4 Volts under operating conditions other than idle.
Old Aug 3, 2014 | 07:15 AM
SSteve's Avatar
SSteve
My FLHTCU 2008 read just over 13 volts at idle most of the time, at times it would go up to just over 14 volts.
After bring the RPM's up past 1500 RPM's while riding, the meter would read just over 14 volts almost always, whether my passing lights were on or off. Sometimes it is a slow steady climb to just over 14 volts from just over 13 volts. Still other times it was almost instant.
I regularly put a tender on it when I'm not riding it. Now, in the last few days of writing this post my regulator took a dive and quit working. Wires good, stator normal specs, rotor normal specs.
Jim, what are your idle and riding numbers? Also, do you have an oiler cooler located just a bit under and in front of your regulator?
JKSHYT
Electrical/Lighting/Alarm
16
Jun 16, 2019 09:14 PM
Daddywags
Aug 28, 2018 05:32 AM
My2Harleys
Jul 16, 2014 06:34 PM
pyronuc
11
Mar 28, 2014 01:14 PM
rjsogard
Nov 22, 2009 07:38 PM
