new voltage regulator issues !!!
Old Jul 31, 2014 | 10:49 PM
stevebou27's Avatar
stevebou27
Stage I
Default new voltage regulator issues !!!
Hi guys just got my first bike its a softail with evo 1340. The bike wasn't charging so I replaced the voltage regulator. After I replaced it after a half hour or so of riding the bike would shut off and then I could fire it right back up. Cannot find this common issue within any threads. I'd appreciate any help . Thanks
Old Aug 1, 2014 | 08:55 PM
kpd's Avatar
kpd
4th Gear
I am having trouble with my charging system too. I did some diagnostics following the instructions in the following thread. It appears mine is the regulator so I ordered one. You may want to try the tests because it could be the stator.
https://www.hdforums.com/forum/touri...r-failure.html
I have a question for you though. Were you able to access the regulators connection to the main circuit breaker? My Clymer says I need to take the wheel off to get to it. I'm hoping there is an easier way.
Old Aug 1, 2014 | 10:11 PM
ajayrk's Avatar
ajayrk
The main breaker is on the rear splash pan snapped into a holder. Stick a screw driver under the breaker and pop it out of the holder. Pull it toward you, there should be enough wire that it will come out far enough to replace it. Best to disconnect the ground on the battery first.
Old Aug 2, 2014 | 07:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
They made Evo Softails for 15 years, don`t be so vague when describing your bike.
A great many electrical changes occurred over that time.
What year is the bike?
HDPursuit
Electrical/Lighting/Alarm
Aug 22, 2018 12:56 PM
0734
EVO
Aug 6, 2014 07:16 AM
Jim Kraft
EVO
Aug 17, 2010 11:35 PM
NCCPainter
Jul 10, 2009 12:45 PM
pyro
Ironhead
Jun 20, 2007 11:41 AM
