key fob programing help me
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the owners manual.
If you never set the code, its 7-7-7-7-7
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use left turn signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The key fob on TSSM motorcycles
must be set so it will operate the alarm system on the vehicle. This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
2. Press left turn switch 2 times and release (should flash 2 times for N American)
3. Press right turn switch 1 time and release (1 flash turn signals)
4. Press left turn switch 1 time and release (2 flashes turn signals)
5. Press and hold key fob button until confirmation is received (2 flashes turn signals which may take 10-25 seconds)
6. If you have two fobs press and hold button on the second until confirmation is received. (2 flashes)
**Right after you receive confirmation that the first fob has been associated. The second fob must be programmed in this sequence if you attempt to program another fob using all the steps only one fob will be programmed**
7. Turn IGN key Off.
Thanks much.
I have 2011 convertible which lost both of it's fob. I have ordered 2 new fob but do not know how to program them, I tried to look in the catalogue but there was no instruction in it. Please help me with this issue. There is no Harley dealer in my region.
Thank you
We have two Fob keys.
One is working.
The other not.
How can I find the code in the first fob ?
I want to put this code in the second fob.
Can someone help me ?
Marc
