Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Thanx for the honorable mention, I'm thinking this time it'll bee a measurable amount higher. Thanx Scott....
Originally Posted by Hillsidecycle.com
Yep, Rosa's tuned off one of our's a while back with the same/same set up that posted just a tick more.
That one had a E carb that was Thunderjetted.
If wanting to step into the deeper end of the pool, then a Wood 8 @ 10.8 cr, with our Stage II Heads will show 95/95, and have one(of several many we've built) in Lyon's Falls, NY, that followed our recipe to the letter, and we tuned it off at 99 hp and 98 ft/lbs, sae.
1990 FXR with 3.37 gearing.
50 plus mpg, and he drives it everwhere.
Scott
The first build was just heads cam and a good tune by hillside, never had a big bore kit done only .005 over to clean the cylinders and i could eat 103"er's for breakfast and go after 110"er for lunch. The w-6 with head work and wisco 10 -1 is a hot ticket. but now i upped it a little to exactly 83.07 " (.030 over) 11 to 1 wisco's fitted to my already done stage II heads and added a w-8 cam and For the first time owning this bike (over 10 years now) I was a little afraid of it, Just wants to keep going faster. I believe I was doing atleast a buck30 and still didn't hit 5500rpm. I will probably never now what it is capable of. and all that without a big bore kit..... Like i've always said "any one can make power with more inches, But to make more power with less is an art" ......Huh......Thanx Scott.
Your 80"er @ 95 hp/95 ft/lbs, sae, says it all.
Scott
