Engine/Transmission Swap
Old Oct 8, 2014 | 10:05 PM
Morpheus515's Avatar
Morpheus515
Default Engine/Transmission Swap
Hi guys,I own a 2006 dyna wide glide with 24,000 miles on it.I've had problems with the inner primary bearing,and transmission won't go into neutral,and valve train noise.I was wondering if a brand new 103 engine and transmission would fit the bike without any major modifications.I don't like the look of the 2014,otherwise I would just buy a new bike
Old Oct 9, 2014 | 05:05 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I wouldn't suspect that you'd need to replace with new to correct those issues?
Scott
Old Oct 9, 2014 | 08:49 AM
djl's Avatar
djl
What Scott says; just fix the problem. The 2006 Dyna's are noted to have problems with the inner primary bearing; pretty common ailment but I don't know anyone that traded up to address the issue.
ron s
May 24, 2020 04:32 PM
ron s
Apr 24, 2017 02:43 PM
Morpheus515
Jun 24, 2014 07:26 PM
Larry Sanders
Mar 17, 2011 08:32 PM
buzzpat1
Jun 29, 2009 03:32 AM
