Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
This winter I plan to pull my heads and get some port/polish done, 1.9 intake valve, etc. While its off will boring the throttle body a few mm be any benefit? Just a 103 with Andrews 57 cams, 2-1 pro pipe, air cleaner and tune it with tts. Going 107 is out of budget and figure headwork best route to add with cams.
I planned on taking them to axtell to get done unless hillside or someone can justify me shipping them vs dropping them off somewhere. I assume that would be part of them boring it is reassembly. I could tear it down but rather let machinist do it. I know a local Indy who could do the heads but know they need done particular to my camshaft
Not enough of a HP gain unless you're going to go BIG STROKER motor and I mean BIG. You may be able to pick up a total of 1-3 HP and maybe 5 TQ overall. A 50 mm TB will handle anything you can throw at it on a 103. Not very cost effective for what it's going to run you.
You want a fast flow rate through the throttle body. If the heads don't flow the rate the larger opening enables, it will not provide a power benefit and be detrimental.
it really depends on what work your doing with the heads.even on a 103",if its going to be a fairly aggressive build,its a very good idea to do the t. body also.one thing overlooked is the runners & port opening.just boring the t. body leaves a lot on the table.stock HD t. bodies can have the runners opened to 1.700.
Heads just 1.9 intake valve, port/polish intake and exhaust ports, upgrade valve seals. The stock springs shouldn't need replaced for the 57 cam for the year head and beehive spring I already have. Run .030 head gasket to bump comp to around 9.8 and want to keep CCP around 200+. The $700 or so a 107 will cost in parts I don't feel I will need as I expect 100/115 once heads are done with stock bore. If the 103 had issues in regards to stock internals I would go 107 but have not heard anything bad outside of cam bearings and lifters which have been changed already.
I don't know that I would do a throttle body right off the bat. I would do my heads and my dyno then decide. When Mike did my tune he didn't mention any need for more flow. The 57's work best with a mild head so I don't know that you would use the extra flow.
