gear drive??
Old Oct 21, 2014 | 06:58 PM
yeoman71's Avatar
yeoman71
Default gear drive??
I own a 2000 road king with a 95" screaming eagle conversion. Is converting to gear drive over chain worth the money and time? And is this something a home mechanic can do easily?
Old Oct 21, 2014 | 07:17 PM
yeoman71's Avatar
yeoman71
I am new to twin cams and could use all the help I can get....
Old Oct 22, 2014 | 03:11 AM
ridedaddy's Avatar
ridedaddy
I am not a pro but gear drive cams are better in the fact that there are no tensioners or chains to worry about and maintain. Also they supposedly make slightly more peak power than a chain drive due to a more accurate time at high rpm. One thing you must due before committing to a gear drive cam is to check your crank runout to make sure you are within spec for a gear drive cam. If you runout is not within spec it not possible to get the correct gear mesh for the gear drives. I'm sure the pros will chime in at some point.
Old Oct 22, 2014 | 05:23 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
There are a couple specialty tools that aid the job along.
You want to check your pinion shaft r/o, and you really want no more than .003" if going to gear to gear.
Scott
Old Oct 22, 2014 | 07:07 AM
prodrag1320's Avatar
prodrag1320
imo,the gear drive set up is the best product to come out for the 99-06 TC`s (just check the run out,as stated earlier)
Old Oct 22, 2014 | 07:34 AM
Hillsidecycle.com
Sponsor
...............and I'll also add if going to that gear drive, with an assumed 85cc chamber/flatop piston from S/E, an Andrews 21G would be a very good choice for that touring machine.
Scott
Old Oct 22, 2014 | 07:21 PM
fidel's Avatar
fidel
its a 95 ci better look for andrews 37 or 26 21 work great in a 88 but not my choice in a 95
Old Oct 23, 2014 | 06:13 AM
Hillsidecycle.com
Sponsor
Andrews 21 is a shoe-in at the advertise compression of those 95" HD kits, for low-mid power in a touring bike.
A 26 wants 9.6-9.7 cr, and a 37 wants 9.8-9.9, to fully optimize the delivery and output of the worth of the installation, or at least from we've found.
Scott
Old Oct 23, 2014 | 06:56 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Gear drives
Without a doubt a gear drive will almost always out perform a chain providing the person installing it knows how to set it up. Back in the 80's an 90's all the small blocks (cars) i built had gear drives. easier to dial in. its all about tuning. A little noisier but so are the right cams.............
Old Oct 27, 2014 | 10:14 AM
yeoman71's Avatar
yeoman71
Just pulled the cam cover this weekend and to my surprise, the gear drive conversion has already been done. Thank you all for the info!!!!
