Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Getting the cylinders bored to 3.875 95ci at a machine shop in town that came highly recommended by my local chopper shop. Motor Tech,$100 for the bore and hone. WISECO Vt Piston Kit 95Ci Domed Standard Bore 3875In 10.5:1 Comprsn VTwin VT2709 $314 ebay, Smiths quick install adjustable pushrods $144,Barnett Heavy Duty clutch spring $30, S&S 585 Easy Start cam $334 ebay, S&S Cycle Premium High-Performance Tappet without HL2T Kit 330-0175 $224 ebay, Baisley LMR Oil Pressure Spring $17.50 $1,163 total for parts plus whatever Galley Motorworks charges for the install. Should get some nice power and torque I think with this build.
Already have installed Thundermax with Autotune, RSD Venturi air cleaner with K&N filter, V&H Black Big Radius Pipes
Do you think I should get the SE 50mm throttle body and larger injectors that come with it? Do you think I'll loss some low end but gain middle top end. What will I gain with this?
No more than you are doing the stock 46mm TB will do fine. If you do go to a bigger unit and injectors you'll likely gain maybe 2or3 hp and 3or4 tq if anything. Not a good return for what you're going to spend but hey, it's your money.
