Pick a cam?
Old Nov 10, 2014 | 09:20 PM
dfowler1's Avatar
dfowler1
Default Pick a cam?
Allright you motorheads, I have my stock cams out and about to install one or the other, Which would be your choice? A Fueling Reaper 543c or a Screaming Eagle 255h. I have both in hand and still can't make up my mind.
Stock 09 Ultra with K&N filter and Rinehart 3 1/2 slipons also a Thundermax going on same time.
http://www.feulingparts.com/reapercamshaft.php
http://www.harley-davidson.com/store...se-255-cam-kit
Old Nov 10, 2014 | 09:31 PM
HD Pilot's Avatar
HD Pilot
Very different cams, 255s should be better in the lower rpm range, 543s in the higher rpms.
You know better than us where you want your performance to shine the most.
Old Nov 10, 2014 | 09:38 PM
EP50's Avatar
EP50
Try one of each...
Old Nov 10, 2014 | 09:41 PM
dfowler1's Avatar
dfowler1
Most of my riding is backroads and hi ways, 55mph plus and at that speed I am about 2200 rpm in 6th. I just don't want to put the 255s in and want more on the upper mid. Not going to drag or anything but got a great deal on both cams.
Old Nov 10, 2014 | 10:00 PM
HD Pilot's Avatar
HD Pilot
If you like hanging around 2200 rpms then I would go with the 255s. Plus if you do 2 up very much they should serve you better.
Old Nov 10, 2014 | 10:02 PM
Stang951's Avatar
Stang951
I picked 204 cams when I was trying to be sold 211 cams. Why, because those cams put the power in the rpm range that I ride in most often, but I also like to "hot rod" around now and then. This is more of a personal choice and I think that you need to look closely at what the cams AND the tuner are going to do for you in the range you ride in.
Sorry if that doesnt help, but it has been the best bit of wisdom that was given to me when I made my selection.
Old Nov 11, 2014 | 06:02 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
In "cam only" builds in the touring bikes, we use a lot of Andrews 48's here.
Scott
Old Nov 11, 2014 | 11:20 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Thanx for the laugh
Edith, get me two more beers, Which one's Archie? Aw Edith you know it doesn't matter as long as I don't have to get up.......
Originally Posted by EP50
Try one of each...
Old Nov 11, 2014 | 12:20 PM
dfowler1's Avatar
dfowler1
I believe I am going with the 543s and see what happens. I am just thinking the 255s will run out on me when I do wind it up. But I still have them sitting here so if I don't like them I can change them. Exhaust is a pain in the *** though!!!!!
Ranger Rick
Sep 14, 2016 09:19 PM
Holzarbeiter
Dec 6, 2011 11:52 AM
gmc1999
Nov 20, 2009 07:11 PM
jcsurf
Exhaust System Topics
Mar 20, 2009 06:20 AM
2wheeltom77
19
Jul 31, 2008 01:22 PM
