Andrews 48H or Red Shift 525?
Old Dec 31, 2014 | 12:50 PM
yuba7tom's Avatar
yuba7tom
Stage III
Default cams
Have two harleys now, but I used to build chevy 350 race engines. Always went with the cam DURATION, not the lift....big gains, big, big difference. Just sayin.
Old Dec 31, 2014 | 12:55 PM
djl's Avatar
djl
Originally Posted by qtrracer
One thing that is overlooked is the compensator. The acr's engage EVERY time the engine is started not just when the operator remembers to activate them and using cr's them takes considerable strain off the comp as well. I would consider them must haves in 07 and up bikes.
Good idea and considering the compensator issues, probably worth doing regardless of which cam the OP chooses.
Old Dec 31, 2014 | 01:04 PM
djl's Avatar
djl
That's all I am saying; look at the total cam profile and see if the profile is suited for one's riding style; look at everything. However, the first check, for me, is setting compression targets for the build and narrowing down cams based on that criteria that should deliver performance where desired. JMHO.
Old Jan 3, 2015 | 11:59 PM
djl's Avatar
djl
One last thought for roadrideking. Take a look at the S&S EZ Start cams for one with a similar profile to the 48 or the 525. I haven't looked but I suspect there is one that would work and would allow the OP to run the higher CCP without compression releases.
moharley2000
Milwaukee Eight (M8)
15
Dec 6, 2018 12:02 PM
BlkHillsBagger
Sep 7, 2018 03:38 PM
sthnrebjr
Jan 31, 2017 08:00 PM
98 FLHX
EVO
Jun 20, 2009 09:03 AM
wadejesu
Mar 17, 2008 04:58 PM
