High Output Cams
Old Dec 30, 2014 | 07:20 PM
32roadking's Avatar
32roadking
Default High Output Cams
Hey, anybody know specs on the new 2014-15 high output cams?
Thanks and Happy New Year
Old Dec 30, 2014 | 07:26 PM
gusotto's Avatar
gusotto
If the cams you're wondering about are the cams in the baggers that are "suppose" to be close to the SE 255 cam.
Don't know how true, just wondered myself.
Old Dec 30, 2014 | 07:47 PM
djl's Avatar
djl
Camshaft IVO IVC IV lift IV dur IN LC EVO EVC EV lift EV dur EX LC Overlap LSA
OEM 07 up -12 30 0.465 198 111 38 4 0.465 222 107 -8 109
OEM Rushmore 3 30 0.511 213 103.5 43 10 0.511 233 106.5 13 105
SE255 6 25 0.556 211 99.5 48 7 0.556 235 110.5 13 105
Old Dec 30, 2014 | 08:52 PM
tander002's Avatar
tander002
Stage I
Default Cams
check out page 75 in Screamin' Eagle Pro racing catalog
Old Dec 30, 2014 | 09:20 PM
mikeman54's Avatar
mikeman54
Welcome from Michigan tander002.
Old Dec 30, 2014 | 09:28 PM
TriGeezer's Avatar
TriGeezer
Oh...that clears it up.
Old Dec 30, 2014 | 09:59 PM
gusotto's Avatar
gusotto
Hard to compare....
Would have been easier if all the columns lined up under each other.
I had to print it out, then draw lines to compare.
Yes, it was confusing.
Old Dec 31, 2014 | 12:30 PM
djl's Avatar
djl
Originally Posted by gusotto
Hard to compare....would have been easier if all the columns lined up under each other. I had to print it out, then draw lines to compare. Yes, it was confusing.
Well, the columns were lined up when I posted the information; can't help what happens after I post. You could have said thanks for the information instead of bitching about how confusing the information was. I guess I should have taken the time to set up an Excel spread sheet to avoid any inconvenience; my bad.
If one understands cam profiles, it wouldn't have been confusing at all.
Old Dec 31, 2014 | 12:34 PM
qtrracer's Avatar
qtrracer
I one understands cam profiles, it wouldn't have been confusing at all.
No good deed goes unpunished.
Old Dec 31, 2014 | 02:14 PM
djl's Avatar
djl
True that!
