T-Man 577
Old Jan 30, 2015 | 07:47 AM
DeweysHeads's Avatar
DeweysHeads
I will tell you this. The Tman 577 is a very quiet running cam every time, no special anything needed to make that happen.
Here is a dyno sheet, stock block 103
Specifications:
103'', PORTED HEADS 80.2CC, TMAN 577 CAMS, .030''HG, STG. 1 ROUND A/C, FULLSAC HEADPIPE, RECORED CVO MUFFLERS, REKLUSE TQ CLUTCH. STOCK TB AND INJECTORS
Old Jan 30, 2015 | 09:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default with head work.
Those are good numbers but with head work, so what was the static compression on that? Do you have any charts with an 80"er n the 577?
Specifications:
Old Jan 31, 2015 | 09:30 AM
DeweysHeads
Sorry that is a twin cam grind only
That one is set at 10.55:1
Old Jan 31, 2015 | 02:15 PM
98hotrodfatboy
Default Yea
Thats what I thought...
Old Nov 9, 2015 | 02:34 AM
Brisdog's Avatar
Brisdog
Stage II
Default 577's in 103ci
I have t-man 577's in my 2013 Fatbob. I have upped the compression 10.5:1 with SE domed forged Pistons. No headwork. 102.33 hp, 109.85 tq. Comes on strong around 2500 rams. Great Cam. Dyna attached.
Next is the headwork......suggestions anyone? T-Man has suggested the T-man Street Performer 103 for about 115/115, that is with a throttle body.
Old Nov 9, 2015 | 06:18 AM
azlou66's Avatar
azlou66
Originally Posted by Hillsidecycle.com
He is not a dunce, by no means, but would like folks to believe that he does it for an actual living.
He does NOT.
Scott
When I spoke with him last week he didn't "hide" his day job from me.
Maybe because I also work in aerospace???
Old Nov 10, 2015 | 01:51 AM
garett742's Avatar
garett742
Specifications:
With these ported heads is that just a P&P or does that have bigger valves as well?
How much were they decked to achieve that compression. I'm looking into building something close to this! Who did these heads, I need to get mine done this winter.
Old Nov 10, 2015 | 08:42 AM
DeweysHeads
I ported the heads
They were decked about .040, all new parts but original springs were tested and pressures equalized. 1.9 intake valve, 1.575 exhaust valve. AV&V valves and guides.
Old Nov 10, 2015 | 02:02 PM
98hotrodfatboy
I would think those exhaust valves are a little small for a tm 577..
Old Nov 10, 2015 | 03:26 PM
DeweysHeads
It wasn't to small to make 114 or so square with a solid torque curve. Stock throttle body and injectors, stock 103 block. This is not a high flyer, these results happen consistently.
