Compression release question
Old Feb 15, 2015 | 07:01 PM
kidsid99's Avatar
kidsid99
Default Compression release question
If I put a set of 103 heads off of a 2015 motor that are already drilled for compression releases on a motor that is not set up for compression releases, what are my options? The 2015 heads are drilled for compression releases underneath the rocker boxes. Do I have to put either manual or electric set on there that looks like dealer get over $300 for?
Thanks in advance for any answers to my question.
Old Feb 15, 2015 | 07:11 PM
jetmech74's Avatar
jetmech74
cant put a manual set there, you'll need to buy the Harley ACR kit (or similar) or plug the holes
Old Feb 15, 2015 | 07:34 PM
qtrracer's Avatar
qtrracer
As stated before you can plug the holes. However if you buy the hd acr releases @40 each and 1 hd wiring harness@50 thats not quite 300 now is it. I'd put em in.
Old Feb 15, 2015 | 08:06 PM
smitty901's Avatar
smitty901
Put the compression releases in you be glade you did
Old Feb 15, 2015 | 08:08 PM
kidsid99's Avatar
kidsid99
Ok I see them now. Earlier was looking in Fat Book and they are much more expensive. Thanks for reply. Putting 103 cylinders and heads off a 2015 on my 2009 96ci to go with my cam.
Old Feb 16, 2015 | 06:40 AM
prodrag1320's Avatar
prodrag1320
if you use the ACR`s,you can just wire them to your starter,no need for the harness (or they can be plugged and have the heads machined for MCR`s)
Old Feb 17, 2015 | 06:11 AM
grbrown's Avatar
grbrown
Wink
Given the choice I would go for ACRs! Just press and go. I've been using them for several years now and cannot see the point of messing with manual ones.
Old Feb 17, 2015 | 06:27 AM
prodrag1320
wait till they fail,which we`ve seen a fair amount do
Old Feb 17, 2015 | 12:09 PM
qtrracer's Avatar
qtrracer
Put mine in 2009 never missed a beat. I did however vent crankcase to atmosphere
Old Feb 17, 2015 | 01:08 PM
djl's Avatar
djl
That's what I did; plugged the ACRs and installed MCRs. I don't like adding electrical **** that can fail anywhere, anytime and my carbureted all bore 107 really doesn't like to start under full compression; it does all sorts of nasty things and will pull a battery down in no time at all.
TruckerXbones
May 9, 2019 02:06 PM
MColton76
Apr 4, 2013 03:48 AM
harley_jeff
Exhaust System Topics
Oct 20, 2011 07:21 PM
willies75
Aug 31, 2011 06:50 PM
maineultraclassic
Oct 4, 2007 06:13 PM
